Clip polygon by lines
  • Aug 26, 2021 8:50 PM UTC
  • 10 replies
  • 203 views
ienesaglam60
Forum|alt.badge.img+3
Ekran AlıntısıSelected blue area is polygon. Red lines is line.
I want to cut the blue area according to the lines and create 3 areas.
Best answer by gio
@ienesaglam60​
Hi, the same workbench but now with your sampe data.
Tolerances for snapping have been changed accordingly.
Workspace is attached.
Here is picture of result
PolygonClipping
danilo_fme
Forum|alt.badge.img+58
  • Aug 26, 2021 9:43 PM UTC
Hi @ienesaglam60​
Did you try use the transformer LineonAreaOverlayer?
Thanks in Advance,
Danilo
ienesaglam60
  • Aug 27, 2021 6:45 AM UTC
Yes i try but I can't get what I want.Thank you
gio
Forum|alt.badge.img+15
  • Aug 27, 2021 9:17 AM UTC
@ienesaglam60​
Coerce area to lines.
Snap your cutting lines to those (vertexsnapping in your example). Use polygon as anchor to keep polygon as is. (topologybuilder is also used for this as the later versions have tolerance)
Build area.
danilo_fme
  • Aug 27, 2021 10:41 AM UTC
Please, could you send us your data sample?
Thanks in Advance,
Danilo
gio
  • Aug 27, 2021 11:19 AM UTC
@ienesaglam60​
Hi here is an workbench
Using Topologybuileder or Interscetor.
Crucial is of course Snapping and snappingtypes. (depends on quality on the inputobjects. In my case i drew your examples in Inkscape so it was not topologicaly tight))
Grets.
gio
  • Aug 27, 2021 11:24 AM UTC
a pic
PolygonClipping
ienesaglam60
  • Aug 27, 2021 12:38 PM UTC
Thanks in Advance,
Danilo
attached sample dataset.
ienesaglam60
  • Aug 27, 2021 12:39 PM UTC
attached sample dataset.this ws I'm not sure if it's appropriate.
gio
  • Aug 27, 2021 1:32 PM UTC
@ienesaglam60​
PolygonClipping
ienesaglam60
  • Aug 27, 2021 2:40 PM UTC
This is awesome . Thank you so much.
