Clip Polygon
  • Dec 20, 2018 10:52 AM UTC
  • 5 replies
  • 95 views
HI. I have a shapefile of Dissolved points and another shapefile of a polygon. Now I want to clip the polygon overlapping on the point file. Please note that the whole polygon area does not cover all the dissolved points.
  • Dec 20, 2018 11:07 AM UTC
I'm guessing you want to keep only the points inside the polygon?
Have you tried using the Clipper transformer?
  • Dec 21, 2018 5:28 AM UTC
Hi...Yes, I tried the clipper, but that is not giving me the output I want. Thanks anyways.
  • Dec 21, 2018 8:10 AM UTC
Can you perhaps give us some more details: what did you try and why isn't the output what you need? That way it's easier to help.
fmelizard
Forum|alt.badge.img+22
  • Dec 21, 2018 6:13 PM UTC
Hi @mukhtar_gf Do the points and polygons have the same coordinate system? Do they align if you view both in the Data Inspector - without background maps? You also might want to try the SpatialRelator, SpatialFilter, or PointOnAreaOverlayer.
aurelienchaumet
Hi. Try to put reprojector at each reader to be sure that you're in the same coordinate system.
Then connect the polygon shape to a clippe clipper port and the point shape to the clipper port.
Don't forget to parameter attribute part of the clipper transformer as you wish.
And everything is gonna be alright ;)
