Clip line for each overlapping polygon
  • April 11, 2019
  • 6 replies
  • 156 views
I'm trying to intersect a line with several hundred polygons the problem I'm having is there are several polygons that overlap each other, so when I run the lines and polygons through the clipper I end up with some incomplete segments. Pictured is an example where the overlapping polygon got the start of the line segment thus not a complete line for the red selected polygon.
I've tried a bunch of different transformers and end up with the same result or worse result no matter what.
Update: the help mentions intersector for my situation but I can't figure out how to get at the result I need still.
xiaomengatsafe
Forum|alt.badge.img+11
In the Clipper, do you happen to have the Tolerance set to anything other then "None"? If those polygon boundaries are very close, the length of the would be segment may be shorter than the tolerance. Which is why it was not created.
It would really help if you could attach a small sample of your data and the workspace, so we can help figure out what's the cause of this.
Thanks @jlgvii
  • April 12, 2019
@xiaomengatsafe Thanks for the reply, I've uploaded some sample data in the parent post. I've messed with the tolerances and can't seem to get the needed result.
  • April 12, 2019
Which one illustrates your desired Clippers better?
Left: The line should be split into 6 parts; Right: The line should be split into 5 parts
  • April 12, 2019
Technically only 4 as there is only 4 polygons in this case. I've attached a screenshot of something that gets the desired output and hopefully is more clear. However this method won't work for the number of polygons I'm working with. I need each polygon to contain the complete line segment.
try this method (if I understood correctly your request) and you will get a segment for every polygon.
  • April 13, 2019
The same approach, a different implementation.
