Clip larger than the boundaries
  • Apr 30, 2019 7:17 PM UTC
  • 87 views
mlupien
Forum|alt.badge.img+7
I am pretty new with FME and I love it.
There is so many testers and transformers that I am a bit lost sometimes.
Anybody has an idea how to clip a raster 100 meters outside the boundaries of a polygon ?
Thank you :)
Mathieu.
Best answer by jdh
Add a Bufferer (or GeographicBuffer if your data is in lat/long) to the polygon prior to sending it to the Clipper.
Polygon -> Bufferer -> Clipper (clipper)
Raster -> Clipper (clippee)
jdh
Forum|alt.badge.img+41
  • Apr 30, 2019 7:26 PM UTC
mlupien
  • May 1, 2019 2:07 PM UTC
Amazing @jdh ! Exactly what I was looking for !
Thank you !
jdh
  • May 1, 2019 2:13 PM UTC
Thank you !
I often use a boundingBoxReplacer between the bufferer and the clipper, so the corners of the rasters are not rounded off to NoData.
mlupien
  • May 1, 2019 4:01 PM UTC
Very good suggestion ! I like it very much !
Thanks again !
