Clip Imagery based on polygon
  • June 28, 2018
  • 10 replies
  • 38 views
checcosisani
Forum|alt.badge.img+14
Hi all
I created a bounding box polygon and I want to use to clip and export raster imagery reading the imagery from my server
Is it correct to use wms reader to read imagery and then ? clipper ?
How can setup the resolution of my clipped output ?
thx
Francesco
  • June 28, 2018
The clipped output will have the same resolution as the intput, i.e. the image returned by the WMS server. You can tweak the WMS parameters (the combination of the bounding box and image size) to manipulate the WMS image scale.
You can also use the RasterResampler, but it works best if the difference between the input and the desired output isn't too big.
checcosisani
  • June 28, 2018
Hi David
thx for quick answer .... but I don't understand why I'm not able to clip the imagery on wms server ..maybe there is some step that I miss ?
do you have any suggestion ?
thx
Francesco
  • June 28, 2018
Hi David
thx
Francesco
Impossible to say without more information. Can you post some screenshots and some log entries?
checcosisani
  • June 28, 2018
Yes maybe I have to zoom in into the area to clip using the search envelope but I can read the min xy max xy from external data
checcosisani
  • June 28, 2018
below a screenshot
  • June 28, 2018
below a screenshot
You can convert those attributes to a polygon feature using the 2DBoxReplacer and send it into a FeatureReader configured for your WMS. The polygon will be used as the search envelope. You can configure the image size inside the WMS reader parameters, together with the bounding box it will define the scale of the returned image.
checcosisani
  • June 28, 2018
Hi David
thx for support step by step I'm approaching the result but.....
now I would like to export one clipped image for every polygon (I created an Id unique for each polygon) used to clip
I have to use fanout with POlygon-ID
thx
Francesco
  • June 28, 2018
Hi David
thx
Francesco
I'm not sure I understand. What happens when you run the current workspace? Do you get any error messages?
checcosisani
  • June 28, 2018
No error
I just want to export one single image per every polygon because at the moment my output is composed by only one image
No error
What about using the FeatureReader for your WMS read. Then you can pass in the search envelope values to the reader.
