clip autocad data by viewport
  • Mar 2, 2015 4:23 AM UTC
  • 8 replies
  • 83 views
Hi everyone,
Is there any chance to clip my data in autocad format .dwg by existing viewport in paper space? the reason I want to do that is to get rid of all unwanted data in the drawing.
Any help is deeply appreciated
  • Mar 2, 2015 4:33 AM UTC
in fact I can not see if a feature is in paper space or model space. Is there any format attribute showing that?
gio
Forum|alt.badge.img+15
  • Mar 2, 2015 4:24 PM UTC
the autpcad reader has a option to "read paperspace" under parameter options.
Setting this wil get you  the papaeraspace as non-geometric objects
Expose the attribute "autocad_space" to check type. ("autocad_entity" will be "viewport as wel) Format attributes will contain the extents.
you can get extent, create a box and  clip or select objects outside of this paperspace.
gio
  • Mar 2, 2015 5:24 PM UTC
The extent is in "autocad_extended_data{0}.real{1}" tm autocad_extended_data{0}.real{4}"
  • Mar 3, 2015 12:23 AM UTC
Hi Gio!
Thanks a lot for your response.
1. I do not have 'autocad_space' as a format attribute.. My version of FME is 2013 SP2, may be it appeared in later versions...
2. Yes, I see viewports as 'autocad_viewport' in 'autocad_entity' field as you mentioned. But as you said, it has no geometry and my
"autocad_extended_data{0}.real{1}" tm autocad_extended_data{0}.real{4}" are empty (in fact I do not even see the {4} one).
3. I assume that in your case viewport extents are given related to paperspace coordinates. And this won't correlate to modelspace coordinates (correct me if I'm wrong). Is there a way to integrate/convert one into another?
Cheers!~
gio
  • Mar 3, 2015 11:51 AM UTC
I used fme2014sp2.
 tried it on some text objects, and it looks like extent in modelspace to me.
Though i seem not able to get placement tright, it is somewhat offset.
I hav'nt played with these parameters before your question inforum though.
Blue box (created from paperspace values) in picture is actualy more over the word "there" in the autocad paperspace.
I clearly am not full knowledgeable on this yet.
  • Mar 4, 2015 4:25 AM UTC
Gio,
Thanks a lot for your try anyway... I assume you sketched the modelspace objects relatively close to 0,0 point that's why you can see the viewport. If your objects are in world coordinates I am afraid the viewport will be too far from the obejcts to clip by boundaries. I am thinking of some tool to define the center of the viewport relatively to modelspace coordinates. And extracting extents and scale of the viewport you can clip the objects.. I doubt FME can handle that but it was worth asking anyway...
Thanks for your time and efforts, appreciate that!
Kim
  • Mar 4, 2015 4:27 AM UTC
Another thing I am curious of.. If you see "autodesk_space" format attribute, can you define the layout name? (as you may have multiple layouts and multiple viewports in 1 drawing)
gio
  • Mar 4, 2015 5:21 PM UTC
Yes there are 2 in the pic, one near the origin, as you said and one large.
Only one viewspace was defined the other empty.
Both have thear standardnames, but these names do not appear. There are 2 rows output with no geometry and wich are defined as paperspace in the attribute.
The highlighted one was defined and has a larger extent.
The format attributes are somewhat cryptic...and not helpfull. I also can not find any viewport origin in the data, alas.
Seems, half usefull. But maybe i need to study it more closely.
