clip a DTM using a not round boundary but export to rounded points
  • January 23, 2014
  • 10 replies
  • 101 views
Dear all,
i have the following problem:
Using a DGN file i get different informations:
- DTM points
- Breaklines
- a perimeter
what I do:
- interpolate / generate a DTM
- clip this DTM using the boundary
Result:
What I get:
- A XYZ file or ASCII grid where the coordinates are not rounded to the full meter (e.g. 423545.455).
This is caused by the perimeter which is not rounded to full meters
What I need:
- The result should be a DTM with coordinated at the full metere, e.g. 423545.000
Is there any solution to tell FME that i want to export the DTM in a way that each DTM cell should be on straight coordintes?
Thanks for the help!
Thomas
fmelizard
Forum|alt.badge.img+22
  • January 23, 2014
If it is as you say:caused by the perimeter that is not rounded, have you tried rounding the perimeter before clipping?
Itay
  • January 23, 2014
Thanks Itay, for the quick reply.
This would be an option. Since i'm fairly new in FME could you give me please a hint how i could round a perimter which is a closed unregulary shaped polygon.
But still the possibility to tell FME that it should export grid cells on straight meters should not be so difficult. I would rather say that this is required very ofter from the user (who wants to work with raster data on x.34054 and such stuff) :-) .
Thomas
fmelizard
  • January 23, 2014
Hi Thomas,
In that case I think the RasterCellValueRounder is what you are searching for.
Itay
  • January 23, 2014
Dear Itay,
I think we have a small missunderstanding.
The content of the RasterCell represents the height of the DTM cell. This value can be whatever (not rounded) thats fully OK.
What i need is the coordinates of the cell (X and Y) are on staight meters, this means .000.
This can not be done by a simply rounding of the X and Y coordinates, since with a difference in this lateral coordinates i would have different height values in Z.
best regards
Thomas
fmelizard
  • January 23, 2014
Hi Thomas,
That makes sense, why would you want to round the cell values....
Anyway, You can coerce the raster into polygons and round off the coordinates, but that is where my line of thought ends.....
Itay
  • January 24, 2014
Thanks Itay,
i will look into the problem again.
But I'm still surpriced that its so difficult to tell FME to export a DTM on straight coordinates.
Have a nice day!
Thomas
  • January 24, 2014
If you are using the NumricRasterizer to transform the DTM points to a raster, I think you can specify cell sizes (X / Y Cell Spacing) and ground extents (Minimum X / Y, Maximum X / Y) by rounded values. You can also use the AttributeRounder to round numeric attribute values, if necessary.
Takashi
fmelizard
  • January 24, 2014
Yes, it this option is also available in the SurfaceModeller, Thomas, which transformer are you using to create the DTM?
Itay
gio
Forum|alt.badge.img+15
  • January 27, 2014
U could greate a 2Dgrid overlayed on the perimeter and use this to capture
the heights to integer coordinates.
U will have to rasterize your DTM and then resample the raster to get DTM-heights wich are on those integercoordinates.
I assume that the DTM points are not all on exact integer coordinates to start with (?)
  • January 28, 2014
Thank you Gio,
this is exactly what I thought could be the solution.
The problem is, that I'm very new at FME and i can not find the correct Transformers:
- Generate a Grid on certain coordinates
- fill this grid with interpolated heights from the original DTM
If you could give me please a transformer name or another hint would be heighly appriciated.
Thanks
Thomas
