CKANConnector - Reorder resources within a dataset - Place new resource at the top of the listing
  • Nov 18, 2022 8:25 PM UTC
  • 96 views
jpbarnes
Using the CKANConnector to Create Resource on OpenGov, works great the issue I'm having is how do you reorder the resources ( or place the new resource at the top of the ordering) by default the sequence number is Max + 1 placing the new resource at the bottom of the listing. In this case we have a few hundred Resources under that one dataset.
debbiatsafe
Forum|alt.badge.img+24
Hello @jpbarnes​
Reordering of resources is not currently supported in the CKANConnector.
However, you should be able to use the HTTPCaller transformer to call CKAN's package_patch REST API endpoint to do this. Note that you must be authorized to edit the dataset and the groups that it belongs to in order to be able to successfully call this endpoint.
I have attached a workspace demonstrating this approach and I hope it helps.
jpbarnes
  • Nov 30, 2022 9:03 PM UTC
Thank you, I have been on a much needed Vacation, sorry for the delayed response. This looks much easier than what I was thinking.
