chose between two raster
  • Feb 4, 2019 1:58 PM UTC
  • 97 views
New user here,
I try to make an atlas in a geospatial pdf.
I have multiple vector map with a main shapefile with multiple polygone (it's the foundation of my atlas)
But I want to chose between 2 raster image (ecw) as base layer for each map,
I want to chose the good raster based on the size of the main feature of my atlas.
I created a BoundingBoxAccumulator where I can have the area of the futur map to display.
How can I switch between the two raster based on the value of the area ?
if area >XXXX then put raster 1 as base layer
else put raster two as base layer.
Thanks in adavnce for your help.
  • Feb 4, 2019 3:33 PM UTC
Not clear what the question point is. If you are looking for a way to calculate area of the bounding box, the AreaCalculator or the @Area function would help you.
  • Feb 4, 2019 4:25 PM UTC
sorry for not being clear. (English not my mother tongue)
My issue : I have 2 ecw file and a parameter (the area of the bounding box)
What is the procedure to choose the good file based on this third parameter ? it's a conditional choice.
The answer may be very simple, I'm a complete beginner...
thanks anyway for your time.
daveatsafe
Forum|alt.badge.img+24
  • Feb 4, 2019 6:16 PM UTC
Hi @b.dorbani,
You can use an AttributeRangeMapper to map the area of the bounding box to the basename of the desired raster, which is added to a new attribute. Then use a FeatureMerger to merge the geometry from the raster onto the bounding box, by joining the new attribute on the bounding box to fme_basename on the raster.
