Check the direction of wall
  • Dec 11, 2023 8:05 AM UTC
  • 90 views
kumarkannan1980
Participant
I am facing an issue where wall was not rendered properly by the FME inspector as it has direction issue. I tried "SurfaceNormalExtractor" but I didn't get any information out of the transformer. Please find the screenshot. Could you please help me in this regard.
Same issue was posted 6 years back https://community.safe.com/s/question/0D54Q000080hfTrSAI/citygml-generation
Wall not render properly in FME inspector
renditionDownload (2)
renditionDownload (1)
daveatsafe
Forum|alt.badge.img+24
  • Jan 22, 2024 10:54 PM UTC
Hi @kumarkannan1980​,
Please try using the PlanarityFilter transformer to extract the surface normals. In the transformer properties, set Surface Normal Output - Expose Surface Normal to Yes.
For the top faces of the walls, check that _surfaceNormalZ is near to 1.0, and that the faces have Front appearances set.
