Hello,
Does anyone know how to create triangles between two 3D lines using FME tools? The triangles can also be vertical.
Hello,
Best answer by takashi
The attached workspace example describes a way to create TIN surface (Mesh) from a pair of 3D lines. Assuming that the two 3D lines have the same number of vertices.
