Check for non ASCII characters
  • Mar 25, 2019 11:23 AM UTC
  • 5 replies
  • 506 views
david.benoit
I am building a data quality control layer and currently checking data formatting.
As part of the format checking, I would like to ensure all data will not contain uncommon characters, which I guess, means anything OUTSIDE the normal ASCII character set (0 - 127).
Efficiency would be imperative here considering this is a very small part of a very large processing "layer" and will likely involve checking every character in a potentially very large dataset.
I'm guessing regex would be ideal but I cant figure out a way to implement regex without explicitly listing every single strange character, and I'm unfamiliar with regex as it is...
Any recommendations?
Thanks!
Forum|alt.badge.img+54
  • Mar 25, 2019 11:41 AM UTC
Regex to search for non ASCII
[^\x00-\x7F]
Efficiency wise it might be more efficient to do something in python, although depends on exactly what the outcome needs to be. Do you need to identify the non-ASCII characters or just identify values that contain them?
david.benoit
[^\x00-\x7F]
Thanks very much.
I notice it also picks up on double quotes (") but that is probably for the best.
  • Mar 25, 2019 11:59 AM UTC
Thanks very much.
That regex doesn't match double quotes for me
david.benoit
ah. My mistake. its actually this character thats getting picked up:
as opposed to:
  • Mar 25, 2019 1:36 PM UTC
Concerning performances and regex, it would be interesting to hear from Safe if the StringSearcher / AttributeValidator compiles the regex once before the first feature, or if the regex is compiled once for each feature. For huge datasets and/or complex regexes the performance difference can be quite noticable.
@mark2atsafe ?
