check every cell if it is located between two attributes or not
  • Feb 26, 2020 6:27 PM UTC
  • 87 views
gogopotter90
Forum|alt.badge.img+14
Hi Guys,
i have excel file ,i want to make comparison
as
if sum 1 < base A < sum 2
if yes ,
so as give me the output
i want to check for every cell in base A is the value between sum1 and sum 2 in the each row or not .as example check the first cell of base A (65452 ) is between sum 1 and sum 2 at first row or not then continue to check 65452,first cell of base A with the second row of sum 1 and sum 2 or not .
i want to check for each cell in base A ,if this value between sum1 and sum 2 for each row .
after finish checking 65452 so start with 65438 and so on so it will check for each cell with 10 rows
i want to do the same also for Base B ,if the value between sum 1 and sum 2 and if yes gives me output and continue check for this cell till the end
till i finish with all field cells in base A and base B
Thanks in advance
FME version 2018
Best answer by markatsafe
@gogopotter90 Thanks for including a small sample dataset.
I think you need to do a full outer join for each "base A' to every row in the table and the same for "base B". You can simulate this using FeatureJoiner by creating a temporary key attribute, i.e. _key = 1. Then you can apply your test. The workspace might look something like;
Workspace attached (2019.2): fullouterjoin.fmwt
  • Feb 26, 2020 6:51 PM UTC
gogopotter90
  • Feb 26, 2020 6:56 PM UTC
thanks alot i modified it and it is working great
