ChartGenerator Fatal Error - Non-numeric input provided.
  • Dec 13, 2017 7:12 AM UTC
  • 10 replies
  • 136 views
nielsgerrits
Forum|alt.badge.img+67
This one is already solved. Writing is for documentation only as I could not find the solution here.
I had to debug a workbench from a coworker which was failing with the following error:
WARN  |ChartGenerator: Non-numeric input provided.  Please validate that the values of the "X Attribute","Y Attribute" and "Error Attribute" (if supplied) are numeric
FATAL |f_24(PythonFactory): PythonFactory failed to close properly
ERROR |f_24(PythonFactory): A fatal error has occurred. Check the logfile above for details
Due to the log pointing to non numeric input in the ChartGenerator it took me some time to find out that the error was caused by something different: One of the attribute names used in the ChartGenerator in the "Y attribute" contained a space.
I tested this in desktop 2017.1.1.0 / 2017.1.1.1 / 2018 beta (build 18220).
This is a known issue and filed under C133238.
  • Dec 13, 2017 8:40 AM UTC
Thanks for sharing!
felipeverdu
Forum|alt.badge.img+12
  • Jan 17, 2020 12:16 PM UTC
This error is still around in 2019: FME(R) 2019.1.3.1 (20191019 - Build 19643 and FME(R) 2019.1.3.1 (20191019 - Build 19643 - WIN64
Any ideas?
jovitaatsafe
Forum|alt.badge.img+11
Any ideas?
Hi @felipeverdu1,
Is your issue the same as the reported where the error was caused by a space in the attribute? This issue (FMEENGINE-39953) appears to be fixed for FME 2018.1 and 2019.0, would you be able to share your workspace that outputs this error? I'd be happy to take a look at it and see if the issue needs a second look with our development team. Thanks!
felipeverdu
  • Jan 22, 2020 9:05 AM UTC
@jovitaatsafe, I attach the workspace for review!
Br,
Felipe Verdúnone2pngraster.fmwt
nielsgerrits
Br,
The source is missing so I can't check myself, but can you add a Tester just before the ChartGenerator to check if the attributes "Alder" / "salaryK" / "salaryM" exist and have numeric values?
Because there are more possible reasons why this error comes up.
felipeverdu
  • Jan 22, 2020 10:31 AM UTC
Hi @nielsgerrits,
The source should be attached now, I believe.
Br,
Felipe
none2pngraster2.fmwt
nielsgerrits
Hi @nielsgerrits,
Br,
Felipe
Heya @felipeverdu1 you have either filled salaryK or salaryM:
This is causing your issue. If you map the missing values to zero (NullAttributeMapper) the chartgenerator wont fail.
I understand this does not help you, but the missing values are causing the error.
At least the error message is correct :D
nielsgerrits
nielsgerrits
@felipeverdu1 I think I fixed your workflow, if I understood correctly what you intended.
Got some nice scatters:
none2pngraster2_edit2.fmwt
felipeverdu
  • Jan 22, 2020 2:55 PM UTC
Hi @nielsgerrits
It works really fine! You understood what I wanted.
Thanks a lot for your time! I appreciate it.
Br,
Felipe Verdú
