Chart Generator to EPS writer
  • Apr 23, 2018 2:44 PM UTC
  • 46 views
hydrolithe
Forum|alt.badge.img+3
Hi, I use FME desktop to generate topografic profils with Chart Generator transformer. It works well and I want to add a EPS (Adobe Illustrator EPS) writer but with many combinations of parameters, it doesn't work and I can't have a profile as eps file.
The goal is to work with this eps file in Adobe Illustrator to have a wide choice of customization.
Is there anyone who has already worked with this case ? And if you have any tips to help me.
Pierre
Forum|alt.badge.img+63
Rather than using a ChartGenerator I would create regular geometry of the profile (swap the Y and Z axes should do the trick) and then write to EPS.
Alternatively, you can try writing to PDF rather than EPS, those can also be opened in Adobe Illustrator
hydrolithe
  • Apr 24, 2018 2:32 PM UTC
Thanks for your answer.
