Chart Generator Bar Chart Background Color Not Changing
  • April 24, 2020
  • 33 views
warrendev
Forum|alt.badge.img+26
I've been experimenting with the chart generator transformer and can't seem to get the background color to change, even after I change the color using the "Background Color" parameter under the Style section. This is for a bar chart. No matter what color I change it to, it will only keep the default white color RGB(1.0,1.0,1.0).
It won't change the color in the preview or after I write it out to a png. The documentation states: "This parameter sets the background color of the chart. The default background color is white, with an RGB value of 1.0,1.0,1.0."
FME 2020.0.0.1
Best answer by debbiatsafe
Hi @warrengis
Thank you for letting us know! I was able to reproduce and have created FMEENGINE-64116 to track this issue.
debbiatsafe
Forum|alt.badge.img+21
  • April 25, 2020
Hi @warrengis
debbiatsafe
Hi @warrengis
Hi @warrengis
I'm pleased to let you know this issue has been fixed in FME 2020.1. You can download the latest installers at www.safe.com/downloads/
Note the background colour only affects the chart area (ie. the area within the minimum and maximum axes).
Thank you for your patience as we worked to resolve this issue!
