Character on chain
  • July 2, 2013
  • 61 views
Hi all,
I have a string like 400*856  The dimensions of a square.
I'm trying to separate both to get the with and hight.
I tried wit the "string searcher" but I'm not sure what i have to put to get the position of the "*"
Then use the substringextractor to make both atributtes.
Please Could anyone give me a clue?
Thanks you so much
Javier
  • July 2, 2013
here is one possibility: use a StringSearcher with the regular expression
(\\d+)\\D(\\d+)
it will separate the two numbers into _matched_parts{0} and _matched_parts{1}
David
  • July 2, 2013
David,
It didn't worked, but you gave me the hint.
I tried with
([0-9]*)[*]([0-9]*)
And worked. :)
I'm not used to these expresions.
Thanks you so much
Javier
  • July 3, 2013
Hi Javier,   The syntax of the regular expression "(\\d+)\\D(\\d+)" is correct, and the StringSearcher with this expression worked in my environment (FME 2013 SP2). You can learn more about regular expressions here. Another way: the AttributeSplitter (specify * as delimiter) could be a solution. For your Information.   Takashi
  • August 3, 2013
Hi Takashi   Thanks you so much for the link.   I can't use the atributteSpliter because the delimiter is not just "*"   Now I have values like   0.7 x 0.8 12 X 0.9   ( I hate them for not to use always the same format)     so I'm trying something like   ([0-9]*\\.[0-9]+|[0-9]+)[*x*|*X*]([0-9]*\\.[0-9]+|[0-9]+)   but when I accept an reopen the transformer the \\ disappears   ([0-9]*.[0-9]+|[0-9]+)[*x*|*X*]([0-9]*.[0-9]+|[0-9]+)
Any hint?
Thanks youSubmit
