Character encoding issues with domain values ArcGis
  • May 2, 2013
  • 8 replies
  • 61 views
I'd like to know if somebody has been problems reading  specials characters (french language) from a domain values from arcgis.
I work with a file geodatabase.
FME don't read these caracteres from the domain value but  work fine when I read from a text field.
Any idea?
  • May 2, 2013
could you please post a specific example?
E.g. what does FME read and what do you expect. Also, which version of FME?
David
  • May 2, 2013
Version: FME 2012 sp1
Viewer:
[URL=http://imageshack.us/scaled/thumb/577/fme21.jpg[/IMG][/URL]" target="_blank">http://imageshack.us/photo/my-images/577/fme21.jpg/][IMG]http://imageshack.us/scaled/thumb/577/fme21.jpg[/IMG][/URL]
Workbench:
[URL=http://imageshack.us/scaled/thumb/585/fme1.jpg[/IMG][/URL]" target="_blank">http://imageshack.us/photo/my-images/585/fme1.jpg/][IMG]http://imageshack.us/scaled/thumb/585/fme1.jpg[/IMG][/URL]
thanks
  • May 2, 2013
  • May 2, 2013
  • May 2, 2013
My example:
FileGedatabase ESRI:
DR_Statut (domain value)= inventorié
METHODECAPTAGE_ID(domain value) = Indéterminé
Nom(text)= Bruno Côté
Viewer FME:
DR_Statut (domain value)= inventori@¢
METHODECAPTAGE_ID(domain value) = Ind@$termin@$
Shapefile Workbench (utf-8):
thanks
fmelizard
Forum|alt.badge.img+21
  • May 2, 2013
Hi Crosadio,
I was wondering if you set the resolve domains option on in the reader ?
according to the documentation that should get you the textual values.
Hope this helps.
  • May 2, 2013
Thanks,
That worked !!
The problem: diference between FME readers: File Geodatabase ArcObjects and File Geodatabase API.
With the last one, I can't see any parametres for setting the resolve domains, but with the former the proccessing is too long.... but it works
thanks
fmelizard
  • May 2, 2013
Glad to hear, I wouldnt use the API reader for any serious ESRI interaction.
Its capabilities are limited.
Cheers,
Itay
