Changes to attributes being used for XML templater
  • Dec 19, 2022 1:06 PM UTC
  • 76 views
Hi all,
I am using FME desktop to publish XMLs out. I'm currently using the XML templater and need to edit one of the attributes that is coming through via a feature reader.
The sub template expression looks like this (redacted some lines due to data):
<data>
<dataid>{fme:get-attribute("dataid")}</dataid>
</data>
There's several other attributes in the XML but I'm not interested in those.
Basically what I would like to do is trim the value in that attribute as the attribute has the current format ABCD*00000000001. I only require the numbers in the attribute and only want these written to the final XML output.
How do I go about making changes to the XML attributes. I have tried looking at XQueries but not got very far.
Many thanks
debbiatsafe
Forum|alt.badge.img+24
Hello @opannell01​
XQuery would be an option if you want to only use XMLTemplater. You should be able to use the XQuery function fn:replace to replace the letters and asterisk symbol in the attribute value with an empty string. For example:
<dataid>{fn:replace({fme:get-attribute("dataid")}, "[A-Za-z]+\*","")}</dataid>
Alternatively, you can also use a StringReplacer transformer with the same regex to get same results for the dataid attribute before the XMLTemplater.
