ChangeDetector - pass attribute from original features to updated features when not one of the selected attributes
  • Sep 24, 2020 4:01 PM UTC
  • 7 replies
  • 141 views
Forum|alt.badge.img+54
In the change detector is there any way of transferring an attribute value from the original feature to the updated feature when it's not either a Key Attribute or one of the attributes listed in the matching strategy
e.g.Capture
mark2atsafe
Forum|alt.badge.img+59
Did you get an answer to this? It looks to me like you can't, which is very weird. I would have expected a Merge Attributes section, like on other transformers. It looks to me like you'll have to follow up with a FeatureMerger transformer to copy info across. Not ideal and definitely worth posting an Idea for.
  • Sep 28, 2020 4:33 PM UTC
No, I'm presuming it's not possible. I couldn't decide whether a FeatureMerger would be the best way, or whether to include the UniqueID as a an Attribute to Match, discard the features that only differed by the UniqueID attribute then fetch the value from a list built in the change detector. Or whether if having to use the FeatureMerger anyway, is the ChangeDetector even worth keeping?
I thought I might be missing something, as I thought it might be a common use, to compare records from say an outside source, with an existing table and then want to update the existing table using a unique key that only exists within that table, not the outside source.
jelle
Forum|alt.badge.img+23
  • Nov 9, 2020 9:37 PM UTC
Hi @ebygomm, I ran into the same issue. Did you post an idea? I couldn't find it.
Using a FeatureMerger seems the best way to me as well.
  • Nov 10, 2020 8:41 AM UTC
No, I didn't get round to posting an idea, it ended up no longer being an issue for the particular workspace i was developing.
jelle
  • Nov 13, 2020 7:40 PM UTC
I mentioned you and @mark2atsafe​  in the idea. I hope that is fine for you both: https://community.safe.com/s/idea/0874Q000000j0MdQAI/detail
  • Oct 31, 2024 2:43 PM UTC
@jelle - the link to the idea is broken but it looks like it’s now possible to preserve original attributes :-)
jelle
  • Oct 31, 2024 2:54 PM UTC
@ebygomm that is nice!
