Change value of multiple rasters
  • Apr 5, 2019 2:42 PM UTC
  • 86 views
Hi all,
I'm quite new with FME, so I hope you can help me. I would like to change the value of multiple rasters. I know you can do that for one raster, but I have a lot of rasters (>200). Is there a way to this?
I'm using FME desktop 2018.1.
Many thanks in advance.
Kees
jdh
Forum|alt.badge.img+41
  • Apr 5, 2019 2:57 PM UTC
Depending on the size of the rasters, you can read them all in with one reader, and use a dynamic writer with the raster file name set to fme_basename.
If your rasters are too large to process in one shot, you can set up a child workspace that does the processing (on a single raster), and then have a controller workspace that uses the pathnames reader to get the paths of the rasters, and send them to a workspaceRunner that calls the child workspace.
  • Apr 11, 2019 12:41 PM UTC
Thanks a lot. This is very helpfull.
