Change the geometry structure in Mongo
  • Dec 7, 2017 6:02 PM UTC
  • 54 views
marsh007
Forum|alt.badge.img+11
Trying to write from SQL server to MongoDB.
It has a below structure:
Geometry
Type
Coords
[long, late], (pt 1)
[long, late], (pt 2)
Can we store all the polygon data like the following:
Geometry:
Cords:
jakemolnar
The GeoJSON specification for the type "Polygon" requires its coordinates to be an array of linear rings (see the spec here).
So we must make geometry like this:
  "type": "Polygon",
  "coordinates":
    [                           <--- this array is an array of linear rings
      [                         <--- this array is a linear ring
        [long0, lat0],          <--- this array is a point
        [longN, latN]
GeoJSON requires this so that Polygons can be Donuts, ie. so that they can have holes. For example, to make a Polygon that looks like this:
4  ___________
  |/ /_/_/_/ /|                <--- the shaded areas are part of the polygon
  |/ |_____| /|
  |_/_/_/_/_/_|
0             4
We would make a GeoJSON polygon like this:
  "type": "Polygon",
  "coordinates": [
    [ [0,0], [4,0], [4,4], [0,4], [0,0] ],       <--- first ring is exterior
    [ [1,1], [1,3], [3,3], [3,1], [1,1] ]        <--- next ring is interior
Maybe if you are just trying to access the exterior ring, then your JavaScript can be something like:
if (geometry.coordinates.length > 0) {
   var exterior_ring = geometry.coordinates[0];
   // do something with ring...
marsh007
  • Jan 5, 2018 8:48 PM UTC
  "type": "Polygon",
  "coordinates":
        [longN, latN]
4  ___________
  |/ |_____| /|
  |_/_/_/_/_/_|
0             4
  "type": "Polygon",
  "coordinates": [
Hi @jakemolnar, we are not using JavaScript. Is there any workaround please?
jakemolnar
Hey @fmeuser_gc, then what are you using to access the Polygon data?
Anyway, one workaround I can think of is to convert your polygons to lines (https://knowledge.safe.com/questions/4730/how-to-convert-polygons-to-lines-and-vice-versa.html), since lines have the representation you are looking for:
  "type": "LineString",
  "coordinates": [
    [ long0, lat0 ],
    [ longN, latN ]
