Change from RGB to HSV or Ycbcr
  • Jul 17, 2015 6:55 AM UTC
  • 190 views
Looking to do histogram matching. From research, the preference is to be in a color space with intensity, therefore HSV or YCbCr. I've tried RGB matching but on the darker sets of satellite images, it does not match well when its 'brightness' increases.
Is there something I can do/use in FME to convert from RGB to HSV ?
Can I do this in python? Read in a feature and output a HSV image?
Best answer by helmoet
hi @pat8037, may be you get some inspiration from this website: http://www.rapidtables.com/convert/color/rgb-to-hsv.htm. I also attached a workbench implementation. Just a bunch of AttributeCreators, basically.
transformcolorrgb-hsv.fmw
helmoet
Forum|alt.badge.img+8
  • Aug 4, 2017 1:41 PM UTC
kdrygalski
  • Dec 19, 2019 4:05 PM UTC
Hi, can You republish this workbench?
mark2atsafe
Forum|alt.badge.img+59
@kdrygalski - Here it is: 9912-transformcolorrgb-hsv.fmw
Tip: If you find a bad link like this, use right click > download and it should work.
