Change color on faces by attributes
  • August 23, 2023
  • 163 views
Hi! I have a big Workbench which does a slope and aspect calculation on roofs to evaluate the potential of solar panels.
I have solved everything except setting different colours on my faces based on the calculated effect by a colour-range. I want to export the extruded 3D polygons to Cesium ION as Cesium 3D tileset to minimize loading time.
See print screens on my workspace below, i have tried maybe 100 different settings on AppearanceSetter and AppearanceStyler without result the only colour visible in the Inspector is the default grey. 4321
daveatsafe
Forum|alt.badge.img+20
  • August 23, 2023
Hi @amajeptroll​,
It would be helpful to have a screenshot of the Geometry Xquery dialog in the AppearanceSetter, and the Feature Information window when you click on a resulting geometry in the Data Inspector.
  • August 24, 2023
Hi! @daveatsafe​
I have not done anything with Geometry XQuery but i added a screen shot of it aswell as the feature information. 65
daveatsafe
  • August 24, 2023
Hi! @daveatsafe​
The AppearanceStyler is basing the appearance color on the 'fill' attribute, but this attribute is empty on your feature. Please try changing the conditional to be based on 'fme_fill_color' instead.
  • August 25, 2023
@daveatsafe​
Ah! I had accidentally deleted that info in an attribute manager, that explains the matter, thank you very much for your help!
