Change attribute data type in an InlineQuerier at an intermediate step in an FME workspace
  • January 10, 2016
  • 10 replies
  • 167 views
Can I change the data type of the area calculator attribute ? it is taken as string by default and I am facing trouble when I do a max function on the column that has all the area values
Best answer by takashi
Did you set proper data type to "_area"?
fmelizard
Forum|alt.badge.img+22
  • January 10, 2016
Where are you doing a max function? FME's functions will all automatically turn strings into numbers if need be. Can you advise what the error message is and where it occurs? In general, the goal with FME's design was that you needn't worry about data types throughout the transformation process (though we are moving to allow more control of that as time goes on), but that instead we'd automatically look after things for users and convert when need be.
erik_jan
Forum|alt.badge.img+26
  • January 11, 2016
Can this be a problem with decimal "," (comma). I have seen this habit in the Netherlands before. What happens if you use a StringReplacer, replacing the comma with a point before getting the maximum value?
  • January 11, 2016
Thanks for your reply. I do the max function on the '-area' field after having calculated the area of a polygon layer using the area calculator transformer.
There are no error messages. The problem here is that, since the _area field is given a char(200) by default, the max function treats the column values as string, thereby not producing the desired max number...for example 52345 is chosen as the max value among 52345, 1590567, 3170438
  • January 11, 2016
I already have the area stat in decimal. What I am trying to overcome is the string data type of the field that contains the area. When I output data after doing the area calculation, the area field is assigned a char 200 by default. I need fme to use a decimal type instead
  • January 11, 2016
I have some webhooks that I am migrating to a new FME Server, these were previously working on another FME Server instance. But now that I have migrated to a new FME Server these webhooks are returning HTTP 500. I have looked at the logs and in the catalina log there is this message
Invalid character found in method name [lv[endof...]. HTTP method names must be tokens
The request headers coming out of python look like this
{'User-Agent': 'python-requests/2.24.0',
'Accept-Encoding': 'gzip, deflate',
'Accept': '*/*',
'Connection': 'keep-alive',
'Authorization': 'fmetoken token=token',
'Content-Length': '0'}
In the datastreaming log in FME Server I found this
Thu-23-Jul-2020 10:21:35.970 AM   FATAL    http-nio-80-exec-6   412007 : Service failed: java.nio.file.AccessDeniedException: C:\ProgramData\Safe Software\FME Server\resources\system\temp\requestdata\9058908488982796417
When I paste the webhook into my browser with the token it works fine but when I use the same URL with the python request library I get HTTP 500.
Has anyone had a similar issue?
  • January 11, 2016
What exactly do you mean by "when I do a max function"? Could you give an example?
  • January 11, 2016
Sorry for the ambiguity. After the data goes through areacalculator transformer, I use an inlinequerier with the following query to find the largest polygon among those that have the same 'long_side'. The result of the query is lexicographical
SELECT * FROM area where _area in (select max(_area) from area group by long_side)
This is the input file
This is the output I get
The desired max value for the 2 records that have long_side = 0.23986593... is 134292143 but as we see in the output it is 50523846.
  • January 11, 2016
  • January 11, 2016
Thanks. I didn't know the existence of the 'ellipsis' button there...The thing is that it shows up only when you click that cell ! Somehow narrowly missed it :-(
In fact, the SQL Query window opens up in the same manner in the inlinequerier ! But thanks ! now I know something new
erik_jan
  • January 11, 2016
I suspect what @erik_jan is getting at, is that you should verify that you use the correct decimal separator. Some locales use a point, some use a comma. If you use a different decimal separator than the current locale, your numbers will be treated as strings.
Yes, David is right. That is what I was trying to explain. Local settings can cause a different decimal separator (comma instead of point) and therefor your numeric value can be treated as string.
