Cannot convert null string into an integer
  • Jul 3, 2022 2:00 AM UTC
  • 508 views
charry
Forum|alt.badge.img+5
BADNEWS: Cannot convert null string into an integer
(C:\\code\\fme\\foundation\\framework\\util\\stf\\stfutil.cpp:346) class StatusInfo *__cdecl STF_stringToUInt(const class ObsoleteString &,unsigned int &)
... Last 2 lines repeated 6 times ...
this error often display,when read excel 、shp 、 dwg file
  • Jul 4, 2022 6:31 AM UTC
Unless you have a very specific use case (e.g. ongoing support case with Safe), I would highly recommend turning off debug messages in the FME log. They are often more confusing than helpful.
charry
  • Jul 4, 2022 2:47 PM UTC
OK,i will close it,@david_r​  if you know how put one 3d line transform to another 3d line,i dont know how use quaternion,thanks
