Can you remove a standard transformer from FME?
  • Dec 13, 2018 12:04 AM UTC
  • 92 views
davideagle
Forum|alt.badge.img+21
If I wanted to hide a transformer so that it couldn't be added to the canvas in an FME workspace, can it be done? I don't want to do anything drastic, just tuck it away so that another transformer would be used instead. Lets say I didn't want anyone to know the 'Reprojector' existed in order to ensure they always used the CSMapReprojector, is there a file I can edit somewhere to 'comment out' the Reprojector...?
I've tried editing \\transformers\\fmesuite.fmx to no avail.
Many thanks...
Best answer by takashi
I was able to remove the Reprojector by commenting out the transformer name lines for every version, in the "fmesuite.fmx". Like this.
#TRANSFORMER_NAME: Reprojector
Note: If you have saved a backup file for the original "fmesuite.fmx" with the extension ".fmx" in the "<FME_HOME>/transformers" folder, FME Workbnech seems to still load the transformer definition from the backup. Change the extension of the backup or save it into other location.
danilo_fme
Forum|alt.badge.img+58
  • Dec 13, 2018 1:25 AM UTC
Interesting Question @1spatialdave
I'm following now to see updates :)
  • Dec 13, 2018 3:03 AM UTC
davideagle
  • Dec 13, 2018 10:42 AM UTC
Thanks @takashi you correctly predicted my error. I had a backup file with a different name but the same extension and thats why my edits weren't being applied. As usual, thanks!
