Hi
I am trying to filter a dataset to show a features that are in set of values . I am using the Tester transformer with the IN operator. If I were to do this in an ESRI product, I could select the field (attribute) I want to filter and it would list all the unique values for that field to enable me to chose the ones I require. However, I cant see a way to get that info in FME - I have to stick in another transformer and inspector and then copy and paste the values I want into the expression, which is far from an ideal workflow.
Please could someone tell me if there is an easier way to do what I want to do? Many thanks
