Can we delete input file after zipping through ZipArchiver.
  • Jul 16, 2019 6:59 AM UTC
  • 5 replies
  • 115 views
nag
Hello Team,
I have archived a .jxl using ZipArchiver, After zipping the required file can we delete input file from source location.
Thanks,
Nagendra
Best answer by itay
Hi @nshetty,
Or just good old DOS command with the SystemCaller?
debbiatsafe
Forum|alt.badge.img+24
Hi @nshetty
After the ZipArchiver transformer, you can try using the File Copy writer and setting the destination dataset attribute to null as suggested here or using a Python script suggested in this Q&A post (see david_r's comment).
itay
Forum|alt.badge.img+19
  • Jul 18, 2019 9:36 AM UTC
Hi @nshetty,
jdh
Forum|alt.badge.img+41
  • Jul 18, 2019 7:41 PM UTC
Hi @nshetty,
I have a few of those in places :). With FME now being available on multiple OS, python is probably the better way to go for compatibility reasons.
nag
  • Jul 19, 2019 6:15 AM UTC
Hi @nshetty,
Dos command worked for me, But again in confusion with jdh comments.
jdh
  • Jul 19, 2019 2:14 PM UTC
@nag the SystemCaller runs a command line, so something like del c:\\a.txt will work fine on FME installed on windows. However on linux the command is rm (for remove instead of del for delete) so the workspace won't run as expected. I haven't the foggiest idea what a mac command would look like.
The python OS module is a portable way to access system functionality.
os.remove, os.rmdir and shutil.rmtree will all delete the specified file/dir/tree regardless of which OS the workspace is run on.
If everyone in your company uses windows it's irrelevant, if you have a mix of OS environments, it's something to be aware of.
