Can I use FME to write DWG data to paper space
  • July 29, 2013
  • 40 views
zhuxinxin
Forum|alt.badge.img+3
Hi,    I've found a parameter called "Read Paper Space" in DWG Reader. In help document, it says it's only for read. Now if I want to write some data to DWG's paper space, is there any method to use FME to do this?    Thanks a lot
Best answer by zxq
I would also like to know that, looing forward the answers!!!!
Good luck
  • July 31, 2013
Good luck
daveatsafe
Forum|alt.badge.img+20
  • June 22, 2017
Hi @vigood, @zxq,
We have an article demonstrating how to write to paper space at https://knowledge.safe.com/articles/34345/working-with-autocad-layouts.html.
