Can I use FME to create a form to interactively update rows in a SQL Server 2016 database
  • May 7, 2019 5:06 PM UTC
  • 50 views
I am looking for a way to update/load data into a SQL Server database by using FME as an input form
  • May 7, 2019 5:45 PM UTC
FME is not really very GUI-oriented, but it's possible to either use FME Desktop with published parameters or FME Server with the new "workspace as an app"-functionality.
In your workspace you can e.g. use the SQLExecutor or the DatabaseUpdater to do the heavy lifting.
