Can I use FeatureHolder as a solution for portal feature service reader irregularities
  • Oct 2, 2025 3:14 PM UTC
  • 173 views
sammy
Forum|alt.badge.img+27
I was hoping someone who understands how FeatureHolder works can let me know if I can use it successfully to help with an issue I am having.
I have some workspaces on flow that had been working as expected for well over a year but recently I have had two separate ones glitch on me in the span of a few weeks.
I am not 100% sure what went wrong but from looking at the log, the portal feature service reader did not read in all of the records from the table. Looking through the log, I see a line that indicates the metadata fme is accessing lists the correct number of records in the table. However, the summary shows that for that run, it actually read in less than that number.
I have not yet identified what caused the reader to behave this way in these two instances.
My question is:
If I put a feature holder right after the reader, will that solve this problem? Will it make the workspace wait until all of the records are read in? (i.e. the number read in matches the number it was given by the feature service metadata)
Best answer by paul_m
If the reader isn’t bringing in all the features to begin with, I don’t believe the FeatureHolder would help. Are there any filters on the Portal feature layer by default? I seem to remember running into something similar years ago, where after an update to FME or ArcGIS Portal, FME was honoring the default filter on an ArcGIS Portal layer. Alternatively, if you have a newer version of FME, there is a new Esri ArcGIS Feature Service Reader that you could try.
paul_m
Forum|alt.badge.img+26
  • Oct 2, 2025 9:13 PM UTC
sammy
  • Oct 9, 2025 3:50 PM UTC
Thanks ​@paul_m, I don’t think it’s a filter issue as the workspace ran correctly the run before and the run after with the exact same data. So it was just a weird one-off incident where it didn’t read everything in.
I noticed in the log there is a metadata section that gives the number of records in the table.
This is for “Reader 1” (the one that glitched) but it is showing the correct number of records in the metadata section:
INFORM|ArcGIS Portal Feature Service Reader: Requesting metadata for Feature Service at <URL>
INFORM|ArcGIS Portal Feature Service Reader: Found layer/table <Table Name> with ID <##> for feature type <Table>
INFORM|ArcGIS Portal Feature Service Reader: Requesting metadata for layer/table <##> of Feature Service at <URL>
INFORM|ArcGIS Portal Feature Service Reader: Querying layer/table <##> for object IDs, where '1=1'
INFORM|ArcGIS Portal Feature Service Reader: Got 444416 results for layer/table ID <##>
And lower down it shows the total number of records read in from all of the readers.
(wrong number read in, the total should have been 888832 as both tables had 444416 records):
|INFORM|MULTI_READER(MULTI_READER): Done reading 888085 features from 2 readers
And then in the summary it again shows that “Reader 1” read in less than the number of records than what the metadata was saying existed in the table:
|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
|STATS |                            Features Read Summary
|STATS |<Reader 1>                                                              443669
|STATS |<Reader 2>                                                              444416
|STATS |==============================================================================
|STATS |Total Features Read                                                     888085
So I was hoping the feature holder would make sure that the workspace doesn’t continue until all records were read in since the metadata section is showing the correct number of records. But I don’t know how to verify if this will work or not.
sammy
  • Oct 13, 2025 4:47 PM UTC
Ok, FeatureHolder does not solve this problem. I have had the issue occur on a workbench with feature holders after the readers.
Still don’t know what is causing the underlying issue as the workspace ran correctly before and after it didn’t.
sammy
  • Oct 14, 2025 6:00 PM UTC
Also, just in case someone comes across this thread in the future, if it’s a sporadic issue like mine, this temporary workaround might help until you can fix the cause of the issue:
  • HTTPCaller to get the record count for the table
  • StatisticsCalculator to get the count of records read in from the reader
  • Tester to compare if those numbers the same
  • Terminator to kill the workbench if the numbers don’t match
