Can I Transfer/Merge only specific or selected attributes using FeatureMerger
  • Jul 12, 2017 6:42 PM UTC
  • 203 views
I have a FeatureMerger Supplier with the same attribute fields as are available in the Requestor. When there is a matching Supplier, I want to merge the Suppliers geometry and a subset of the Supplier attribute fields into the Requestor, leaving the remaining Requestor attribute fields unchanged, e.g.,
Supplier Attributes Requestor Attributes Action
ORG_CD ORG_CD Requestor value retained
STATUS STATUS Requestor value retained
ACCURACY ---------------------------> ACCURACY Supplier value merged
GIS_ACRES ---------------------------> GIS_ACRES Supplier value merged
LENGTH_FT ---------------------------> LENGTH_FT Supplier value merged
COORD_SRC -------------------------> COORD_SRC Supplier value merged
REPORT_DT REPORT_DT Requestor value retained
The geometry part is easily done, but havn't figure out how to update or merge specific attributes.
Best answer by ebygomm
For the suppliers only keep the attributes you wish to merge, then within the feature merger in attribute accumulation use merge supplier and use supplier for conflict resolution
Forum|alt.badge.img+54
  • Jul 12, 2017 7:02 PM UTC
erik_jan
Forum|alt.badge.img+26
  • Jul 12, 2017 7:10 PM UTC
Two transformers can help here: AttributeKeeper and AttributeRemover.
Remove all attributes from the Supplier that you do not want to merge as @egomm suggested.
Or remove empty attributes from the Requestor if you want them replaced by the same attribute from the Supplier.
  • Jul 13, 2017 11:00 PM UTC
Thanks,
That did the trick. The example I provided was actually a fairly simplified version of the real problem, but in the end the solution you provided, generated the results I was looking for.
Thanks again for your quick, complete and easily understood solution.
