Can i create a reverse pivot table?
  • Jan 5, 2020 4:58 PM UTC
  • 6 replies
  • 146 views
craftydutchie
Hi there! I wonder if it's possible to create a list from a matrix, very much like how I'd do this in excel (see this tutorial). I currently have field names as below (there are actually 20+ years) and what i need is a separate record for each year. Is there a way of doing it? I'd do it in excel but it's not working for me for some reason - plus I'd rather incorporate it into my work flow.
I tried the attribute exploder but this became a bit of a mess.
Thanks!
Renee
DistrictIndustry (short)20172018201920202021Herefordshire, County ofAgriculture etc171.2176.9182.2187.9192.3
danilo_fme
Forum|alt.badge.img+58
  • Jan 5, 2020 6:29 PM UTC
Hello @reneewsp
There is a interesting link recorded video about pivot :
https://knowledge.safe.com/articles/31701/transpose-a-table-using-fme.html
Thanks,
Danilo
craftydutchie
Hello @reneewsp
Thanks,
Danilo
Thanks @danilo_fme - yes I did read this but I couldn't work out how to "reverse" pivot - i.e. create a table with the fields District, Industry and year. I'll have another go.
  • Jan 5, 2020 10:52 PM UTC
The screenshot below illustrates a possible way I can think of. Assuming that the years are consecutive integers. The regular expression ^\d{4}$ matches a string consisting of just four numbers.
Result:
Alternatively this Python script works as well.
# PythonCaller Script Example
class ReversePivoter(object):
    def __init__(self):
        pass
    def input(self, feature):
        beg, end = 2017, 2021
        years, values = [], []
        for y in range(beg, end + 1):
            year = str(y)
            years.append(year)
            values.append(feature.getAttribute(year))
            feature.removeAttribute(year)
        for year, value in zip(years, values):
            newFeature = feature.clone()
            newFeature.setAttribute('Year', year)
            if value != None:
                newFeature.setAttribute('Value', value)
            self.pyoutput(newFeature)
    def close(self):
        pass
Hope this helps.
bwn
Forum|alt.badge.img+26
  • Jan 6, 2020 3:04 AM UTC
Result:
    def __init__(self):
        pass
            year = str(y)
            years.append(year)
            if value != None:
    def close(self):
        pass
Hope this helps.
Yes, ListExpressionPopulator or ListPopulator are the transformers I would use too as the dedicated FME Transformers for "Reversed" pivots.
Forum|alt.badge.img+54
  • Jan 6, 2020 9:20 AM UTC
It's also possible to use an attributeexploder
craftydutchie
Thanks @ebygomm - that works beautifully simply, and thanks to @takashi 's answer i know what the ^\\d{4}$ means too. Brilliant, thanks all!
