Can I call a published FME workbench on FME Server using a .bat file?
  • Apr 3, 2019 4:52 AM UTC
  • 80 views
raaaju1990
Forum|alt.badge.img+11
I have a workbench published on FME Server. Now, I need to call that workbench using .bat file and run it. Is that possible?
I have tied calling a local FME workbench using .bat file but never a published work bench from FME Server.
Thanks you.
  • Apr 3, 2019 8:35 AM UTC
As far as I know that isn't possible, you'll have to use the publishing wizard in FME Workbench to publish to FME Server.
You should consider voting for this idea:
https://knowledge.safe.com/content/idea/23653/fme-server-workspacetransformer-batched-publishing.html
raaaju1990
  • Apr 3, 2019 8:38 AM UTC
Actually, the workbench is already published. I just need to call the published workbench using a .bat file. Is that possible?
  • Apr 3, 2019 8:53 AM UTC
The easiest way to start a job on FME Server from a batch file is using the FMEServerConsole command line client:
https://docs.safe.com/fme/html/FME_Server_Documentation/ReferenceManual/Interactive_Command-Line.htm
itay
Forum|alt.badge.img+19
  • Apr 3, 2019 10:02 AM UTC
IF you can do a GET in the batch to the published workspace, then I think I will work.
You can get the URL to your workspace from the FME Server UI.
