can a primary key be a timestamp value
  • Mar 2, 2020 11:11 AM UTC
  • 528 views
I am reading from a postgresql database. Attribute [publication_time] has a primary key and type timestamp. In the postgresql database this attribute has values, but FME 2018.1 inspector shows no (blank) values.
Can timestamp as primarykey be the cause?
Kind regards
Kees
Best answer by david_r
I know it doesn't answer your question, but I would argue that for almost all use cases it's not a great idea to use a timestamp as a primary key.
Some arguments: https://dba.stackexchange.com/questions/168356/is-using-timestamp-as-primary-key-good-idea-mysql-mariadb
For efficiency and ease of use, it's difficult to beat an integer primary key generated from a sequence defined in your database. If you dabble with synchronization or distributed datasets, I would recommend using a GUID primary key.
  • Mar 2, 2020 12:49 PM UTC
It seems that the problem is caused by the potgresql database. There is a combined primarykey of 2 attributes. Can FME solve that problem?
Kind regards
  • Mar 5, 2020 8:41 AM UTC
  • Mar 9, 2020 10:17 AM UTC
Thank you David
