Call Transformer within TCL shutdownscript
  • Jul 21, 2015 8:28 AM UTC
  • 44 views
Hi everybody,
I wrote a shutdown script for logging, now I want to call a XMLFormatter at the end of this tcl script to linearize my output. Is this possible and how?
I guess the XMLFormatter would need the Parameters:Formatting Type, XML Input and Output File
Other question, how can I run an other workspace within tcl, so that it also works with the FME Server?
Background:
I write a xml file with the aixm writer and want the output (xml file) to be linearized. Therefor I want to use the XMLFormatter.
Thank you,
Mel
Best answer by takashi
Hi Mel,
As far as I know, there is no way to use any transformer in the shutdown script.
Just an idea.
As a workaround, this shutdown Tcl script might work to linearize an XML file. Assume that "XmlFilePath" parameter value indicates the existing XML file path.
if {$FME_Status == 1} {
    set file [open $FME_MacroValues(XmlFilePath) r]
    set text [read $file]
    close $file
    set text [regsub -all {>\\s+} $text {>}]
    set text [regsub -all {\\s+<} $text {<}]
    set file [open $FME_MacroValues(XmlFilePath) w]
    puts -nonewline $file $text
    close $file
Takashi
  • Jul 21, 2015 5:04 PM UTC
Hi Mel,
Just an idea.
    close $file
    close $file
Takashi
