Calculation using ExpressionEvaluator
  • Feb 20, 2025 4:36 AM UTC
  • 169 views
leanne_michael
Hi all - fairly new to FME here.
I am trying to do a calculation using the ExpressionEvaluator to calculate tree protection zone (TPZ) estimate, and round to 2 decimal places.
The formula I’m using is @round(@Value(average_dbh_value) * 0.12, 2)
I also need to incorporate min and max values into the output. Min is 2 and Max is 15. This is where I’m getting stuck. Would someone be able to provide a suggestion on how I can possibly achieve this?
Thanks
Leanne
Best answer by ctredinnick
If you mean to cap the value to a minimum of 2 and a maximum of 15, you can do that with a max and min function like so.
@max(2,@min(15,@round(@Value(average_dbh_value) * 0.12, 2)))
geomancer
Forum|alt.badge.img+71
  • Feb 20, 2025 6:30 AM UTC
You can calculate Min and Max using a StatisticsCalculator.
Use Group Processing to calculate these values on specific groups of input features, grouping by one or more attributes..
ctredinnick
Forum|alt.badge.img+22
  • Feb 20, 2025 9:12 PM UTC
leanne_michael
Thankyou! The above formula worked. Yes - I did mean cap the value to a min 2 of 2 and a max of 15.
Appreciate the help.
geomancer
  • Feb 21, 2025 8:09 AM UTC
You can also use the clamp function for this:
@clamp(@round(@Value(average_dbh_value)* 0.12, 2), 2, 15)
