Calculation in a list
  • Feb 9, 2014 4:49 PM UTC
  • 167 views
Hello,
I have a many objetcs with a list (LIST_A) with N elements and a list attribute ATTR_1, i would like to know a smart way to do a expression evaluation on ATTR_1 on all elements of the list (without doing list explode doing the calculation with expression evaluator and doing a list builder).
Thanks in advance.
fmelizard
Forum|alt.badge.img+22
  • Feb 9, 2014 5:24 PM UTC
Depending on the expression needed the list based transformers can be used. Although the possibilities are not great  certain statistics and simple expressions can be done .
  • Feb 9, 2014 11:48 PM UTC
For example a simple one, like multiply by 2 the ATTR_1 on all elements of the list.
  • Feb 10, 2014 12:39 AM UTC
I would use PythonCaller when it's desirable to avoid list explosion.
# Python Example
# Assume every list element can be interpreted as numeric value.
import fmeobjects
def multiplyBy2(feature):
    for i, value in enumerate(feature.getAttribute('MyList{}')):
        feature.setAttribute('MyList{%d}' % i, float(value) * 2)
