Calculating the number of polygons touching one polygon
  • May 26, 2016
  • 182 views
mygis
Forum|alt.badge.img+14
I was wondering what would be the best way to find the number of adjacent polygon of a single feature polygon in the same dataset such as shapefile for instance. I tried the SpatialRelator and connecting the same features in the supplier and requestor bu the results are not correct. Thanks.
Best answer by erik_jan
Another option would be the NeighborFinder with a distance of 0. This will allow you to get a list of closest candidates (all touching (or overlapping) polygons. If you have all as candidate, be sure to substract 1 from the count as the polygon itself will also qualify.
  • May 26, 2016
Have you tried to use an AnchoredSnapper before the SpatialRelator? Make sure to use Segment Snapping.
erik_jan
Forum|alt.badge.img+26
  • May 26, 2016
mygis
  • May 27, 2016
Hi @erik_jan thanks, that is correct, I added a listElementCounter to get the numbers right. Polygons with no numbers are rejected, but that it no issue.
