Calculating percentage of a value based on another value.
  • November 7, 2017
  • 426 views
Hi there,
I've searched a few threads on here about calculating percentages, but nothing seems to quite summarize what I'm looking for.
I have several polygons, each containing an attribute of "TotalKm" and "MinorKm"
The "MinorKm" represents roads inside that are of a lower class or quality.
I simply want to calculate the percentage based on the "TotalKm", like this example:
MinorKmTotalKmPercentageKm156025%15020075%
I tried playing around with the ExpressionEvaluator to do this, but I could't quite create the correct expression for this.
Thanks in advance,
Best answer by david_r
Try the following:
Expression:
@Value(MinorKm)*100.0/@Value(TotalKm)
  • November 7, 2017
I think the ExpressionEvaluator should work fine. What expression have you set and what happened?
  • November 7, 2017
Try the following:
Expression:
Hi takashi,
Well I've tried a few with little success, but as embarrassing as it is to share this here, this is the chaotic string I came up with last (Math fail) :)
@Value(TotalKm)-@Value(Minorkm)/@Value(TotalKm)*100
David's expression works perfectly, and is also much more elegant :)
Thanks a lot to both of you!
