Calculate the nodata in a raster based on other values?
harmen_kampinga
thank you for reading my question! And maybe you have an idea? Please let me know!
It's about: filling the nodata gaps in a raster.
So, I have downloaded a DTM raster file. It's based on a pointcloud and some classes are filtered out, like water, building, vegetation, bridges. That leaves some nodata holes in the raster. I like to recalculate them, based on the nearest cell values. In the past, I did this with GIS and some neighbor tools for rasters, but I can't really find how to do this in FME.
I have tried the RasterDEMGenerator and also the RasterConvolver, but without any good results... maybe I don't use them well or maybe I should use a completely different approach? No clue anymore.
Any help is appreciated!
Best,
Harmen
caracadrian
Forum|alt.badge.img+23
  • March 15, 2021
I would try the NumericRasterizer or SurfaceModeller.
As a bonus you can first use RasterCellCoercer to extract the pixels into individual points before the NumericRasterizer or RasterDEMGenerator or SurfaceModeller.
jdh
Forum|alt.badge.img+33
  • March 15, 2021
The RasterDEMGenerator ought to work. It uses the same underlying engine as the SurfaceModeller.
What issues are you having (why aren't the results good)?
harmen_kampinga
thanks @caracadrian​ and @jdh​ !!
Appreciated your help, but not clear at the moment what does the job at its best
But I'm getting there bit by bit.
