Calculate raster data to clip white/black border
  • Oct 5, 2018 7:37 PM UTC
  • 7 replies
  • 196 views
I have to generate dynamically an polygon to cut the border of my raster image.
i read this articel: https://knowledge.safe.com/articles/18764/setting-alpha-vs-nodata-color-and-numeric-data.html
Option #2 sounds good, but there is a static polygon (creator transformer) used.
i have to replace the creator and add something like a polygon generator based on my raster data.
this is a demo pic. the red polygon is the polygon mentioned that I would have to calculate.
I thought of something that compares the neighboring pixels and the strong deviation from this creates the line of the polygon. is there already a transformer? or is there another suitable solution for my problem?
sorry, i'm quite new with FME
edit: picture updated. the area with green lines should be removed
  • Oct 5, 2018 10:57 PM UTC
As far as I see the image you posted, looks the clipping operation has been performed fine. Could you please elaborate what the problem is?
  • Oct 6, 2018 12:31 AM UTC
no there is nothing clipped. bad image but top and left of the image is a white border.
picture updated. area with green lines should be removed
  • Oct 6, 2018 1:07 AM UTC
Hi @cloc91, try clipping the raster by the red polygon using the Clipper. Make sure that the "Preserve Clipee Extents" parameter in the Clipper is set to "No".
  • Oct 6, 2018 8:29 AM UTC
I know, that i have to use the clipper. But first i have to generate the red polygon. This step is not clear how to generate the red polygon. The red polygon should be dynamic, because i have other tiles with different borders.
  • Oct 6, 2018 2:08 PM UTC
If the raster has Nodate definition and the white area is filled with Nodata cells, you can use the RasterExtentsCoercer (Extents Type: Data MBR Extents) to create a rectangle polygon representing the bounding box of the data area, which can be used as the clipper to remove the unnecessary border area.
  • Oct 8, 2018 7:04 AM UTC
no, raster files has no NoData definition.
i think, i need something like the nearblack function from gdal https://www.gdal.org/nearblack.html
i can call it via batch or python, but is there a transformer, which does the same?
  • Oct 8, 2018 1:47 PM UTC
If you can consider the cell value in the white area as Nodata, you can set the Nodata (maybe 255?) to the raster with the RasterBandNodataSetter.
