Calculate polygons angles to horizon
yahyanar
I have a lot of polygons that represent buildings and I want to rasterise them but before I do I need all the polygons to be parallel to the horizon. I need to create a tool that calculates the polygon angles and then use these angles to rotate the buildings accordingly.
Best answer by DanAtSafe
Hi @yahyanar Try this
which uses the BoundingBoxReplacer to get the angle of the longest side.
danilo_fme
Forum|alt.badge.img+44
  • August 6, 2024
Hi @yahyanar
Please, could you send a dataset to test?
yahyanar
  • August 6, 2024
here I uploaded some buidlings which I want to calculate the dominant angles and use them to rotate the buildings to get them horizontal.
thanks in advance
DanAtSafe
Forum|alt.badge.img+18
  • August 9, 2024
yahyanar
  • August 14, 2024
Hi @DanAtSafe,
Thank you very much for your support. I will try it and give you a feedback.
yahyanar
  • August 14, 2024
Hi DanAtSafe,
I am using FME 2021.2 and it seems that BoundingBoxReplacer does not have Long Side Angle parameter. When I choose Replace with: 2D Oriented Bounding Box, I got only 2 options (see attached).
any suggestions?
DanAtSafe
  • August 15, 2024
Hi @yahyanar The azimuth was added to BoundingBoxReplacer in FME 2022.1
Here’s the work-around if you can’t upgrade:
yahyanar
  • August 15, 2024
Hi @DanAtSafe,
Thank you very much.
I have used HorizonAngleCalculator instead of AzimuthCalculator (HAC is upgrad version of AC). However, as you can see in the figure attached only one feature of the center points entered the process and finally, I got rejected.
DanAtSafe
  • August 17, 2024
Hi @yahyanar Did you change the ExpressionEvaluator so that it calculates the angle to rotate with _angle instead of acAngle?  In your Navigator, go to Workspace Parameters/Translation and change “Rejected Feature Handling” to “Continue Translation”.  Then you’ll be able to see the reason why FeatureMerger_3 is rejecting features.
yahyanar
  • August 17, 2024
Hi @DanAtSafe,
Yes I have changed the ExpressionEvaluator to _angle. Also, I have changed the workspace parameters and I got the results attached.
yahyanar
  • August 19, 2024
Hi @DanAtSafe ,
I did some changes where I have added a “Sorter” and I “FeatureMerger” and now the script works probably.
here is the result
