have used this workspace to convert cad to shapefile , i want to get a closed polygons as the cad file was lines , so i tried to use area builder to get it , so if worked on the blocks its ok , but if i want parcels i get it not clear like these images
1- is the workspace that i used to solve the topology and build area with the lines
2- the result
3- first workspace that i used and there was no result because of topology..
can any one help getting the result same as the source at least the geometery and i will take the text layers after
