CAD TO GIS -- creating polygons
  • Oct 4, 2018 2:33 PM UTC
  • 5 replies
  • 152 views
have used this workspace to convert cad to shapefile , i want to get a closed polygons as the cad file was lines , so i tried to use area builder to get it , so if worked on the blocks its ok , but if i want parcels i get it not clear like these images
1- is the workspace that i used to solve the topology and build area with the lines
2- the result
3- first workspace that i used and there was no result because of topology..
can any one help getting the result same as the source at least the geometery and i will take the text layers after
Best answer by fmelizard
In general, it is rare that you don't want both outputs of the snapper going into your geometry building. I'd try ensuring you run the untouched and the snapped together. Check what you've got coming out of each stage by using the partial runs of FME 2018.x - you'll see what linework you have then at each stage and this should help.
stalknecht
Forum|alt.badge.img+22
  • Oct 4, 2018 3:21 PM UTC
Do you have some sample data? Take also a look at the GeometryCoercer transformer.
fmelizard
  • Oct 4, 2018 6:25 PM UTC
fmelizard
  • Oct 4, 2018 6:30 PM UTC
See https://knowledge.safe.com/articles/79739/feature-caching-and-performance.html and http://docs.safe.com/fme/2018.1/html/FME_Desktop_Documentation/FME_Workbench/Workbench/feature_inspection_about.htm for more info on partial runs.
i tried another solution with the geometry coercer transformer , the result was as per the inspector window
these are the result it is very good so far , i'm working on differrent type of data from different sources ..
thanks ..
7- work space
8- lost of some roads polylines
9/10- parcel result
