Hi, I am attempting to load CAD DWG into a File Geo database that has pre defined schema and domains. I get about 117 errors when I attempt this and would like some direction on how to resolve. my writer has an XML workspace Document imported. Am I to use the Attribute value mapper to 'code' all domain or sub type values?
Thanks!!
