CAD to File GeoDatabase with predefined schema
  • Oct 19, 2023 8:13 PM UTC
  • 57 views
pearly1
Forum|alt.badge.img+9
Hi, I am attempting to load CAD DWG into a File Geo database that has pre defined schema and domains. I get about 117 errors when I attempt this and would like some direction on how to resolve. my writer has an XML workspace Document imported. Am I to use the Attribute value mapper to 'code' all domain or sub type values?
Thanks!!
panda
Forum|alt.badge.img+20
  • Oct 25, 2023 6:29 PM UTC
Looks like it failed because SUBTYPE field in the schema is expecting Integer and the the attribute from the data has the value "Curb Inlet "
I couldn't get XML you provided into the GDB for some unknown reason. So I cannot check if the subtype really expecting integer or not. But I think it is supposed to be 5 instead of Curb Inlet.
