CAD Template Flie in Batch Deploy
  • Dec 25, 2019 12:48 AM UTC
  • 41 views
In my translation, the dwg writer has set the template file by using the published parameter "$(SourceDataset_ACAD)". When I run the batch deploy, it seems that the batch deploy can only recognise the first template file.The template file doesn't work in the others.Could someone help?
chrisatsafe
Hi @pw321670,
I don't believe this will work using a parameter to set the template file as parameters can only be set at run time.
Rather, it should work if you create an attribute that contains the path to the template file and set the template file parameter using an attribute value as this will set the value for each feature instead of once at runtime. You can set the Template File using an attribute Value using a FeatureWriter instead of using a DWG writer.
I hope that helps!
