BulkAttributeRenamer after SQLExecutor gives error
  • Dec 18, 2019 3:51 PM UTC
  • 77 views
Dear FME'ers,
I have a question about the conflict resolution of SQLExecutors and FeatureReaders.
I found the issue when I was reading data from a PostgreSQL database. Some of the initiator's attribute names where the same as in the result of my SQL. Therefore I used the option 'conflict resolution'. This because I supposed that the data of the initiator is then overwritten by the data of the SQL script (for the attributes with conflicting names).
After that I tried to rename the output attributes with the help of a BulkAttributeRenamer but got an error. This is not the case when I set the conflict resolution to 'Use Initiator'. There is also no problem when I use a regular AttributeRenamer
If I'm obliged to remove all conflicting attributes then what is the use of the conflict resolution? Or is this a problem related to the BulkAttributeRenamer?
In attachment an example of my question with some extra info. I was able to recreate the issue by reading an Excel file with a FeatureReader:
Our FME version: 2019.1.3.0 (20191007 - Build 19642 - WIN64)
we use python 3.6+
Thanks in advance!
Kind Regards,
Louis Put
Best answer by markatsafe
@louisput Thanks for reporting this and for creating a simple reproduction workflow of the problem. The attribute conflict resolution of the FeatureReader should work as you described. We'll get this addressed.
  • Dec 18, 2019 4:16 PM UTC
erik_jan
Forum|alt.badge.img+26
  • Dec 18, 2019 4:35 PM UTC
A possible work-around could be using aliases in the SQL statement in the SQLExecutor, like:
Select attr1 as myfirstattribute
, attr2 as mysecondattribute
From table
This will rename the attributes from the database to myfirstattribute and mysecondattribute and allows you to avoid the conflicts.
Another work-around would be using the BulkAttributeRenamer before the SQLExecutor or FeatureReader to rename the source attributes and not the database attributes to avoid conflicts.
Hope this helps solving the issue.
  • Dec 19, 2019 9:06 AM UTC
From table
Thanks for the reply. I will rename the attributes of my initiator and remove conflicting attributes before the SQLExecutor. With the help aliases I will then set the SQL output attributes names.
